Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Oil Pan
Replace/Remove
1999 Dodge Caravan how to replace oil pan
1999 DODGE CARAVAN
140,000 MILES • 6 CYL • FWD • AUTOMATIC
YORKIE69
MEMBER
1 POST
I have a 1999 Dodge Caravan 3 litre
my oil pan is leaking. How do i intall a new one?
Jan 23, 2009 at 4:32 AM
Experienced Mechanic
You're lucky. You can remove it without lifting the engine. Drain the oil, and remove the bolts holding it on to the engine. Then it will come off.
If you have trouble, let me know.
Jan 23, 2009 at 9:19 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
