1999 Dodge Caravan help please
TALOR76T
  • 6 POSTS
Transmission problem
1999 Dodge Caravan 6 cyl Two Wheel Drive Automatic
i rcently got codes p0700 and p0740 changed fluid and filter to find that the codes came back up. i have spoke many different mechanics and have gottin nothin solid.i was thinking of changing the solenoid but not sure if its the course of action i should take.any help on this would be greatly appreciated.
Mar 26, 2010 at 4:32 AM
  • 110,251 POSTS
PO700 IS JUST A REFERENCE WHEN YOUR FROM THE ENGINE COMPUTER TO LET YOU KNOW THERE IS CODES IN THE TRANS MODULE. IT NEEDS TO BE SCANNED ON THE TRANS SIDE. IS THE TRANS NOT SHIFTING INTO 3RD GEAR? IF SO, IT IS IN LIMP MODE.
P0704 CLUTCH SWITCH INPUT CIRCUIT MALFUNCTION. I WOULD LIKE TO BELIEVE IT IS JUST A SHIFT SOLENOID, BUT I QUESTION IT MAY BE A PROBLEM WITH TCM.
HAVE THE TCM CHECKED TO DETERMINE IF IT IS OKAY BEFORE REPLACING THE SOLENID.
Mar 26, 2010 at 5:09 AM
TALOR76T
  • 6 POSTS
i have no shifting problems that is what bugs me the most. is the tcm the one on housing or is it internal?and the shift module you say. where is that? just hate to pay big bucks for something that i may be able to do myself..
Mar 26, 2010 at 5:36 AM
  • 110,251 POSTS
The TCM is right above the trans pan (front). It has an aluminum base with a black plastic cover the always seem to leak.
The shift solenoids are in the trans. You can access them by removing the trans pan.
I have a question. Before replacing anything, is the transmission doing anything out of the ordinary?
Mar 26, 2010 at 6:26 AM
TALOR76T
  • 6 POSTS
i have no problems that i have noticed..i was doing a tune up noticed the light was on which it had come on before but for evap which i beleive was just the gas cap.when i hooked it up i had the two trans codes and a egr which i change and that code went away seems to be acting ok. did have a problem with the cruise not kicking it self down on hill..but the egr seemed to fix that
Mar 26, 2010 at 6:46 AM
  • 110,251 POSTS
Try deleting the trans codes to see if they come back. It may have had a bad connection that fixed itself.
Mar 26, 2010 at 6:47 AM
TALOR76T
  • 6 POSTS
i have erased them twice come back on at 40 or less miles
Mar 26, 2010 at 6:55 AM
  • 110,251 POSTS
You have me stumpped. The code you have should force the trans into limp mode. What solenoid did you refer to replacing in the first posting?
Mar 27, 2010 at 1:34 PM
TALOR76T
  • 6 POSTS
the tcm just not sure how..today i cleaned all conections including battery cable shut light down added half a quart of fluid that i was down from change went for a drive with in 10 miles light was on...but my lady noticed that light now does not stay on with start but instead goes off realquick then back on...reading codes today to see if the same...will post results later
Mar 27, 2010 at 6:51 PM
  • 110,251 POSTS
It could be coming from the TCM. However, I would recommend having it checked befor replacing it.
Mar 28, 2010 at 11:30 PM
TALOR76T
  • 6 POSTS
had it diagnosed today...it was the torque converter..they wanted 635.00 to change and tried to sell me the converter for 225. at a discount..lol order one today for 135.00 and so the fun begins with the change out..said there was very little room for the torque to slip and that mine was triple the amount and showed me that all solenoids were working..so i just want to thank you for all the advice and relay this to anyone who maybe has similar problems..once again thank you
Mar 30, 2010 at 9:03 AM
  • 110,251 POSTS
I'm glad to help. Also, I'm glad you got it taken care of. Let us know if you have quiestions in the future, and thanks for using 2carpros.com.
Apr 1, 2010 at 12:22 AM
