1999 Dodge Caravan heater problims
YOKEY3
Heater problem
1999 Dodge Caravan 6 cyl Front Wheel Drive Automatic
the heater goes from cold to hot then back to cold , i can't seem to get a steady temperature and sometimes the heat does not turn on when turned on and when this happens the heat Gage says its getting to hot then it turns on and the Gage go back to normal , how do i fix this problem?
Oct 27, 2009 at 3:39 PM
BMRFIXIT
  • 19,053 POSTS
Sounds as if you low on coolant
checking coolant level would be my 1st step
and then pressure test the coolant system checking for leaks
Oct 27, 2009 at 11:29 PM
YOKEY3
thank you for info it worked wonderfully .
Oct 28, 2009 at 6:15 AM
