1999 Dodge Caravan heater problems
78,000 MILES • 6 CYL • FWD • AUTOMATIC
CVN65
  • 6 POSTS
When turning the heater switch on, the blower motor struggles to stay on. At the same time making a noise and it feels like the blower is going to stop running. I turned the switch on and off a couple of times and sometimes the blower comes on and sometimes it doesn't. If anyone has any suggestions, please let me know. Thanks
Oct 30, 2008 at 9:52 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect the blower motor
place switch at high check for power at the motor connector and check for ground
you can use a 12V test light for the test
and if all ok replace the blower motor
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 30, 2008 at 3:09 PM
