1999 Dodge Caravan fog light
81,000 MILES • 6 CYL • FWD • AUTOMATIC
GRUVDWELLER
I have a damaged fog light. I have a replacement housing. I need to know how to replace it. I can't figure out what is holding the old one in
Jul 30, 2008 at 5:15 AM
MASTERTECHTIM
  • 4,750 POSTS
i just looked it up to see if i could get step by step instructions but its not showing anything. have you removed the lower cowl panel to gain access? when the manual doeswnt give instructions it usually means its pretty straight forward, meaning there is nothing hidden, sometimes it can be tricky, dont get me wrong. i would say remove the cowl under neath it and maybe the inner fender well if that gives you more access. i looked up labor time just to make sure and it pays .2 hours which means it should only take about 12 minutes to replace but you can expect to double that on the first one. sorry i couldnt be more help. i just uploaded the labor time, its hard to see but i just wanted to assure you i did look it up for you andtried to be or more help.
https://images.2carpros.com/forum/automotive_pictures/139033_2carpros_8.jpg
Aug 3, 2008 at 12:04 AM
