1999 Dodge Caravan fan motors
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
KING MARY
i just replaced the water pump on van, still running warm, replaced thermostat, fanmotors will not come on. i have checked relay its good , i have ran a straight wire from fan motors, they work fine. i thinkl there is a short from fan motors to relay??
Aug 24, 2010 at 12:35 AM
LEGITIMATE007
  • 5,121 POSTS
be sure to check the engine coolant temp sensor, as this sends the correct temp to the computer so that the computer can send a ground to the fans and turn on.
Aug 24, 2010 at 8:13 AM
