1999 Dodge Caravan Engine issues
161,000 MILES • 4 CYL • 4WD • AUTOMATIC
GRENEE1
I started to have a problem with the fan belt, somone went in an said it needed a new pump and pulley which affects my power steering, the belt has been replaced twice so now my check engine light is on. Are there companys that come out an give you dianostic test so I can get to the bottom of what needs to be done.
Oct 22, 2010 at 6:57 AM
WRENCHTECH
  • 20,760 POSTS
Autozone will read the codes for the check engine light for free but I doubt that has anything to do with the belt problem.
Oct 22, 2010 at 7:17 AM
