1999 Dodge Caravan Door ajar light
1999 DODGE CARAVAN
169,000 MILES • 6 CYL • FWD • AUTOMATIC
ABNREB
I recently bought this van and it had no apparent electrical problems. Just one week after buying it, everytime I start it the door ajar light stays on even after all the doors are closed. When I shift into reverse it goes away but as soon as I put it into drive it turns back on, this also turns the interior lights on. I think its a short somewhere in the dash area but I'm not sure. Any suggestions?
Sep 10, 2008 at 2:31 PM
BMRFIXIT
  • 19,053 POSTS
Possible bad door switch
Use WD40 and spray all door locks (( close + open few times and spray again))
or
using a scanner will help
scan body module data with all door closed it should shows the bad switch
good luck
Sep 11, 2008 at 7:49 AM
