I still have power running to the blower motor after the ignition is turned off. All fan speeds work with the key removed from the ignition. I swapped the relay and this did not fix the problem. Nothing else is being powered when the key is off. Removing the relay cuts the power to the blower motor.
Mar 18, 2009 at 12:51 AM
