Does your horn work? If not, you need to replace the clockspring. If it does, check the airbag fuse. The clockspring is like the spring in an old wind-up clock, only instead of keeping time, it maintains electrical contact with the airbag, horn and cruise control through the steering wheel while still allowing the wheel to turn.
Oct 11, 2009 at 7:13 AM
