1999 Dodge Caravan A/C FAN RELAY
PEDRO14
Air Conditioning problem
1999 Dodge Caravan 6 cyl Front Wheel Drive Automatic
GOOD MORNING!!! I GOT A 1999 CARAVAN,DOES THE A/C FAN WORK WHIT THE SAME RELAY FOR THE ENGINE FAN?? OR WORK SEPARETLY,WHIT OTHER!!! THNAK YOU!! SINCERELY : PEDRO RIVERA FROM PUERTO RICO!
Nov 1, 2010 at 11:41 PM
WRENCHTECH
  • 20,760 POSTS
No, the blower has it's own relay in the Power distribution box in the engine compartment.
Nov 2, 2010 at 12:07 AM
PEDRO14
[quote:e148a3e4e4="Wrenchtech"]No, the blower has it's own relay in the Power distribution box in the engine compartment.[/quote:e148a3e4e4] REFER TO THE PAST ARGUMENT, IM REFER TO THE OUT-SIDE FAN THAT IS LOCATED AT THE RADIOTOR, ONE IS FOR THE ENGINE AND THE OTHER TURNS ON WHEN A/C IS WORKIN. BOTH WORK ON SAME RELAY OR SEPARATE IT SO WHERE ITS LOCATED? I KNOW THAT THE ENGINE FAN RELAY ITS NEXT TO THE RADIOTOR, IF A/C FAN RUNS WHIT OTHER ,WHERE IT IS LOCATED? NOT BLOWER!!
Nov 2, 2010 at 1:28 AM
WRENCHTECH
  • 20,760 POSTS
No, that's not the way it works at all. There is nothing in front specifically assigned to the A/C.
Both fans are wired to run simultaneously and can come on for either A/C or cooling reasons. They both operate off a single solid state relay.
Nov 2, 2010 at 1:39 AM
PEDRO14
[quote:ac0aa855b5="Wrenchtech"]No, that's not the way it works at all. There is nothing in front specifically assigned to the A/C.
Both fans are wired to run simultaneously and can come on for either A/C or cooling reasons. They both operate off a single solid state relay.[/quote:ac0aa855b5] THANK YOU!!!! GUYS... ITS VERY HELPFULL AND ITS A PLESURE MEET YOU GUYS!!! YOURE FFRIEND PEDRO!! P.R.
Nov 2, 2010 at 1:47 AM
WRENCHTECH
  • 20,760 POSTS
Your welcome,
Positive feedback is always appreciated.
Nov 2, 2010 at 2:05 AM
PEDRO14
[quote:40c8eeefe5="Wrenchtech"]Your welcome,
.[/quote:40c8eeefe5] HEYYY!!GUYSS, IM STILL HAVIN THE SAME PROBLEM WHITH ENGINE FANS,I PUT A BRAN NEW RELAY, BUT DONT START!! ALSO I TEST BOTH FANS TO SEE IF THEY CRANK,AND ITS OK!!! SO I DONT KNOW WHAT IT THE REAL PROBLEM,ALSO I CHANGE THE WATER PUMP,HELP MEEEEE!! IF THERES ANY OTHER RELAY INSIDE THE CAR
Nov 3, 2010 at 9:28 AM
WRENCHTECH
  • 20,760 POSTS
You never asked how to fix the fan nor did you ever post what the symptoms are. You just asked where components were as you knew what you were doing. Here is the schematic
https://images.2carpros.com/forum/automotive_pictures/561653_Cooling_fan_wiring_99_Caravan_1.jpg
Nov 3, 2010 at 9:38 AM
