ABS lite
BUXNBAAS
  • 1999 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 97,000 MILES
Howdy folks. I just replaced both rear brake lines running from the ABS pump to the rear axle. My ABS lite has been on for a long time now and I'm in the mood to make it go away. It came on after I bled the brakes a while back. I read somewhere that you have to do an ABS bleed requiring a $200 computer scanner. Any shortcuts to this? The local parts stores dont rent the computer tool, and I really cant afford the darn thing.
Saturday, August 1st, 2009 AT 2:08 AM
CARADIODOC
  • 34,373 POSTS
ABS light doesn't respond to air in the lines. If there was air, you would have a low mushy brake pedal, and the red warning light would come on.
Normal operation of the yellow light is it should turn on for a few seconds after you turn on the ignition switch, then go out. If it goes out but comes back on right away, suspect a defective sensor or cut wire to one of them. If the light stays off, but comes back on AFTER you start to drive, (from a few yards to a mile), suspect a cracked tone ring on a cv joint or inside the rear brake drum.
If the light comes on right away and doesn't even flicker, suspect a blown fuse, commonly caused by a shorted trailer wiring harness. The computer always has a second power source through a second fuse to run the warning lamp.
Caradiodoc
Monday, March 1st, 2021 AT 12:57 PM
BUXNBAAS
Thank you, I will look at and/or remove the trailer wiring harness, we dont tow with it anyhow. I will check all the fuses also thanks a billion. :)
