1999 Dodge Caravan 3.3 Engine Does Not Start
CHRIS VELAZQUEZ
1999 Dodge Caravan with 3.3 Engine with 95,000 miles does not start. I had the battery, starter and alternator tested and they checked out good. Sometimes the van will start and sometimes it just makes a clicking sound when I turn the key. Can you tell me what the problem might be? Thank you.
Nov 21, 2007 at 6:01 AM
BLACKOP555
  • 10,386 POSTS
check for corodded or unproperly tightened battery cables and terminals, on battery and starter. if that is all good test out the ignition switch.
Nov 21, 2007 at 2:26 PM
LEGITIMATE007
  • 5,121 POSTS
you may want to check for corrosion on the other end of the pos and neg. wiring.
Nov 30, 2007 at 1:11 AM
