1999 Dodge Caravan
TANNEIA
  • 1999 DODGE CARAVAN
1999 Dodge Caravan 4 cyl 149000 miles
Oil is leaking from my engine. After about three weeks (starting with the correct amount of oil), I had to add a quart. 1st, it was diagnosed as a valve cover gasket. Then, they said it was the cylinder head gasket instead. What do you think? Any ideas? If it is the head gasket, what's a fair amount for labor? 1999 Dodge Caravan
Monday, December 29th, 2008 AT 10:37 PM
  • 109,885 POSTS
First I would be sure what it is. Purchase a can of engine cleaner, take the can to the car wash, follow the directions on the can, and clean the old oil off the engine. Next, keep and eye on the engine to see where the oil is coming from. Let me know what you find. Also, chances are it's the valve cover. A head gasket replacement on you car could be around 600 dollars. However, make sure that is the problem. Also, if you can't identify where the leak is coming from, most shops can place a dye in the oil and check for leaks with a black light.
Thursday, January 1st, 2009 AT 2:00 PM
TANNEIA
Thanks a lot! I will try this tomorrow!
Saturday, January 3rd, 2009 AT 7:43 PM
