1999 Dodge Caravan
LISAT
  • 1999 DODGE CARAVAN
1999 Dodge Caravan
how do I change headlamps on my caravan
Thursday, October 30th, 2008 AT 4:05 PM
  • 109,913 POSTS
Hi:
The headlight is actuall replaced from behind the headlamp assembly. Open the hood of the van and locate the headlamp assembly. Going into the rear of the assembly you will see wiring and a round black socket assembly. First disconnect the wiring from it and then turn to the left to loosten the socket. It should pull out of the assembly with the old bulb. Simply remove the old bulb and replace it with the new one. Reverse the process to replace it.
NOTE: Try not to touch the glass part of the new bulb. The oils from you skin can cause the bulb to burn out faster.
If you have any trouble, let me know and I'll try to help you step by step.
Friday, November 7th, 2008 AT 1:46 PM
