1996 Dodge Caravan headlight replacement
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
CEE CHANDLER
How do you replace the headlight on a 1996 Dodge Caravan? Moisture has gotten into it and light output is seriously reduced - any way to fix it without replacing?
Oct 19, 2008 at 4:47 AM
  • 110,245 POSTS
Hi:
The moisture is finding its way in from a crack or seal in the headlamp lens assembly. The only way to repair that is to replace the lens assembly. I recommend checking on ebay or an aftermarket parts supplier on the Internet. You should be able to find the assembly for 30 to 40 dollars. If you get one at the dealer, it will be much higher.
Let me know if this helps, or if you have any other questions.
Oct 22, 2008 at 2:26 AM
