I was driving down the road when I heard a pop and hiss noice and my van shut down and will not start
Wednesday, June 16th, 2010 AT 9:06 PM
BMRFIXIT
MECHANIC
Does it crank but will not start
did you checked for spark or fuel pressure
did you check the oil
need more info
SPONSORED LINKS
Wednesday, June 16th, 2010 AT 9:11 PM
JDS2944
MEMBER
No it does not crank. There is oil in it and nothing leaking from it. It clicks when I turn the key but will not fire. Fluid leaked out onto the road that looked like a mix of oil and transmission fluid
Wednesday, June 16th, 2010 AT 9:25 PM
BMRFIXIT
MECHANIC
Suspect a mechanical failure
also
check transmission by where the axle goes in, passenger side
