1999 Caravan 3.3 engine loud ticking
125,000 MILES • 6 CYL • FWD • AUTOMATIC
TOBYTIGGER
The engine has developed a loud metal hitting metal noise and it sounds like its coming from the rear valve cover. No smoke and car is running fine except for the engine noise. Any idea what the diagnosis might be and if its repairable or is it liekly the engine needs to be replaced?
Aug 9, 2008 at 7:38 AM
MASTERTECHTIM
  • 4,750 POSTS
if the engine is not misfiring i would remove the rear valve cover and see if maybe a valve spring may have broken.
Aug 15, 2008 at 8:45 AM
