the windshield wipers don't work. sometimes they work when you hit the dash or run over a bump int eh road. otherwise they don't work.
Feb 15, 2009 at 3:07 AM
✓Experienced Mechanic
When they stop working, check for power to the motor. If no power, check wiring near the firewall. Also, have the switch checked. If there is power, make sure the motor has a good ground. If it does and still does not work, replace the motor.
