1998 Dodge Caravan Water pump and no start?
179,000 MILES • 6 CYL • FWD • AUTOMATIC
TRINAFRMLV
I have the 3.0L engine. Im pretty sure my water pump went out. it started with a small leak and then it wasnt circulating water at all so the car started over heating. Now it wont start at all. Would the water pump going out effect whether the car starts or not?
Dec 22, 2008 at 10:59 AM
  • 110,248 POSTS
Hi:
The pump will only cause that problem if you really overheated the engine. Regardless, if it's leaking, I would replace it before you end up with a bigger problem.
As far as the no start, have you checked to see if you are getting spark and fuel?
Dec 23, 2008 at 1:02 PM
