1998 Dodge Caravan warning lights
195,000 MILES • 4 CYL • 2WD • AUTOMATIC
JULIETUR
My "service engine soon" light is on, but my van runs fine. All fluids are full. What should I check first to troubleshoot this? Airbag light is also on, as well as the ABS light. I just put new brake pads on the front and filled the fluid. I'm trying to get this van to where it will pass the emmissions inspection in Houston. Thank you
Jan 5, 2010 at 1:33 AM
BUDDYCRAIGG
  • 2,262 POSTS
start with getting the check engine light codes.
http://www.2carpros.com/dia/how_to_scan_trouble_codes.htm
Jan 6, 2010 at 8:55 AM
