1998 Dodge Caravan Van won't start
195,000 MILES • 6 CYL • FWD • AUTOMATIC
LASCANO1960
One day my van wouldn't start. I thought it just might be the spark plugs or something. I changed 4 of them but can't reach the last 2 behind the engine. But, it still won't start. It sounds like it wants to, but, nothing. I thought it was out of gas at first, but, even after adding 4 gallons, still nothing. So, could it be that I let the gas get so low that maybe I plugged up the fuel filter or did something with the fuel pump? Is there any way to get to the fuel filter or pump without taking the tank off. I am a female with no male help, and have learned to do many things on my own. Is this something I can do myself? I don't have any money to take my car somewhere.
Oct 17, 2008 at 12:47 PM
  • 110,251 POSTS
Hi:
The back plugs are tough. However, have you checked for spark to the plugs? If not, take one of the two new one you have left, plug it into one of the front spark plug wires and ground it on the engine. Get a helper to crank the engine while you watch the new plug for spark.
If you have spark, you will need to check for fuel / pressure and volume. I recommend you have someone do this for you because it requires a specal tool.
Let me know if it has spark.
PS: Is the check engine light on? And, your idea about running the fuel too low is possible but unlikely.
Oct 17, 2008 at 4:02 PM
LASCANO1960
Yes, it has spark. I tried that already, but, forgot to mention that. I am sorry. I will see if there is someone who might be able to help me check the other. Thanks. I will let you know.
Oct 18, 2008 at 12:38 AM
LASCANO1960
How am I supposed to use this special tool if my vehicle won't start? Is there some other way to find out if it is this pressure problem?
Oct 27, 2008 at 1:54 PM
  • 110,251 POSTS
The tools I'm refering to are for testing the seperate components without the vehicle running.
I just posted your questions with the other moderators. I'll let you know what they say. Also, one of them may respond directly to you.
As far as the fuel pump pressure, you already answered that question for me when you said there is no power to the coil.
Oct 27, 2008 at 2:14 PM
LASCANO1960
I am so sorry. I don't know what "coil" you are talking about. I feel so stupid. I try to do things myself to save money. But, I did try the "spark" thing. I do have spark. Is that the "coil" that you mention? Again, I apologize for being such a pain in the .........
Lynne
Oct 27, 2008 at 2:27 PM
BMRFIXIT
  • 19,053 POSTS
HI
I think you need to start by checking the videos as they will show you how to do thinks
I will include the link for you to check it out
https://www.2carpros.com/video.htm
its a great collection and I’m sure will help you a lot
then let us know what is missing
if no spark and no fuel suspect crank sensor and or ASD relay
Need a tool or a tester CHECK IT @
https://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 27, 2008 at 2:41 PM
