1998 Dodge Caravan Turn Signals .
122,000 MILES • 6 CYL • FWD • AUTOMATIC
RAYSUP55
Hey guys , My friend bought this van last week and when he brought it to me he said he had an electrical problem . So the problem he is having is someone has what apears to be grounded switch running to the relay under the hood to operate the winshield wipers because , the combo switch is only working for the wiper speed , and high beams tugle . No turn signals , No 4way flashers and the sitch will not signal the wipers on an off . So I have tryed replacing the como switch and it did not . help What could it be ?
Feb 24, 2010 at 2:59 AM
JDL
  • 16,098 POSTS
Hi, check fuse 10--20 amp in power distribution center. Use a testlite, make sure fuse circuit is hot. The turn switch is ground for combo flasher. I'd have to check circuits to and from the combo flasher.
Feb 24, 2010 at 3:25 AM
RAYSUP55
[quote:cff127b77e="jdl123"]Hi, check fuse 10--20 amp in power distribution center. Use a testlite, make sure fuse circuit is hot. The turn switch is ground for combo flasher. I'd have to check circuits to and from the combo flasher.[/quote:cff127b77e] WEll that was the first thing I did do power is good to every fuse also the ac lights flash so its got me thinking in circles ..
Feb 24, 2010 at 3:40 AM
JDL
  • 16,098 POSTS
Ok, I'd have to check circuits at the combination flasher.
https://images.2carpros.com/forum/automotive_pictures/170934_combination_flasher_1.jpg
Feb 24, 2010 at 4:51 AM
