I have a '98 dodge caravan 3 Liter with 220,000 mi. on it. The "service engine soon" light came on a couple of weeks ago and the speedometer went goofy ... I'll be on the road at about 45mph when the speedometer will drop to "0" then jump up and down. Then the transmission will drop into 2nd and stay there for a while occasionally going back up into
drive ... back and forth as the speedometer jumps around. I talked to the local trany people and they said that they didn't think that the problem was with the trany ???
I removed the positive wire from the battery, replaced it and it seemed OK but soon did the same thing. I removed the air intake and sprayed carb cleaner in the intake while the engine was running ... there again, it seemed OK but soon did the same thing.
Can you tell me what is going on?
Nov 30, 2009 at 9:01 AM
