1998 Dodge Caravan speed sensors
172,000 MILES • 4 CYL • FWD • AUTOMATIC
JUNKDODGE
removed vehicle speed sensor, and what i believe to be input or output sensor to clean. only other sensor i see doese not have flat sides to remove sensor with socket, it is round and is located behind dipstick. was told that cleaning these may help problem, but cant figure how the one comes out. also seem to have a problem with fan relays, will this cause eratic shifting. dont want to pull when cold but gets better when warm but does not want to shift wirthout letting off gas or putting in nuetral and back down in drive. Have very limited income and very much hope it is an inexpensive and simple fix. Cant afford transmission shop but van is only vehicle. can u help me with most probable cause. thanx in advance.
Jun 30, 2010 at 6:57 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic_93.jpg
Jun 30, 2010 at 1:42 PM
