Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Symptoms
Misfire
1998 Dodge Caravan SKIPPING
1998 DODGE CARAVAN
23,400 MILES • 6 CYL • FWD • AUTOMATIC
BEVERLYBROWN
MEMBER
1 POST
THE SPARK PLUGS, WIRES, AND DISTRIBUTOR HAS BEEN CHANGED OUT BUT IT'S STILL SKIPPING LIKE IT NEED A TUNE UP
Apr 26, 2010 at 12:57 PM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Apr 26, 2010 at 7:41 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
