HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Serpentine Belt
Replace/Remove
1998 Dodge Caravan serpentine belt
KKMANUEL6263
MEMBER
1998 DODGE CARAVAN
6 CYL
2WD
AUTOMATIC
72,000 MILES
How do I change the serpentine belt?
Sunday, February 10th, 2008 AT 10:39 AM
VANDRAGON
MECHANIC
Call autozone, they have a tool to rent and will tell you how to do it. If your a girl they might do it for you. It's not that hard. Make sure you get a gatorback belt, brand doesn't matter.
SPONSORED LINKS
Monday, February 11th, 2008 AT 1:27 PM
Please
login
or
register
to post a reply.
Related Serpentine Belt Replace/Remove Content
1998 Dodge Caravan P305 Code
6 Months Ago I Got This Code After Check Engine Light Came On. Replaced The #5 Plug, All Ignition Wires, Distributor Cap And Button....
Asked by
RCMutz
1998
DODGE CARAVAN
VIDEO
Serpentine Belt Replacement Dodge
Instructional repair video
GUIDE
Need to change your serpentine belt? This is an easy job in most cases. There are several names used to describe a serpentine belt, including: drive belt, poly-v belt, multi...
1999 Dodge Caravan How Do You Change The Water Pump...
I Have To Change The Water Pump In My Sons Caravan It Is A 1999 How Do I Do It And Should I Change The Timing Belt At The Same Time I Can't...
Asked by
rda1162
2 IMAGES
1999
DODGE CARAVAN
Dodge Caravan 97, Change The Engine Belts.
Hello, I Wanna To Replace The Engine Belts To My Dodge Caravan 1997, 3.0 And I Will Like To Know The Steps, Thank You And Blessings For...
Asked by
amiguisimo
1 ANSWER
1997
DODGE CARAVAN
1996 Dodge Caravan Removing The Ac Belt To Replace...
How Does The Ac V Belt Come Off Dont Appear To See A Tensioneer To Loosen It And All The Pictures Tell Me On Line Is The Adjusting Screw But...
Asked by
mftigger
1 ANSWER
1996
DODGE CARAVAN
1997 Dodge Caravan V-belt Replacement
I Have A Chilton Repair Manual, And It Shows Me Where The V-belt Is, But It Does Not Really Tell Me How To Take It Off. First Off, The...
Asked by
Skeert
1 ANSWER
1997
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Serpentine Belt Change Acura TL 2004-2008
Serpentine Belt Replacement Ford
Online car repair manuals
