1998 Dodge Caravan Possible short in system
1998 DODGE CARAVAN
150,000 MILES • 6 CYL • FWD • AUTOMATIC
TOM1544
When I turned off my vehicle, the engine fans kept running. I came out to a dead battery. When I hooked up the cables to jump start it, the fans came back on. What would cause this problem and drain the battery?
Dec 30, 2009 at 10:02 AM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
disconnect the coolant switch and see what happens fans turn off switch is bad. if it stays on then your cooling fan relay is sticking and needs to be replaced or the fans are shorted to power.
Dec 31, 2009 at 1:39 PM
