1998 Dodge Caravan Oil pressure
120,000 MILES • 6 CYL • FWD • AUTOMATIC
TVHAGMAN2
What can cause the low oil pressure indicator light comes on at idle, when the engine oil level is not low.
Jan 7, 2008 at 5:33 AM
MERLIN2021
  • 17,250 POSTS
Oil pressure has more to do with the condition of the engine...if your engine's bearings a excessivly worn, the pressure will drop. Remove the sending unit, and screw in a test gauge, you should have 5-10 psi at idle warm engine. if it's OK replace the sender, if not, you can try heavier oil...say 20-50 or 30 non detergent!
Jan 7, 2008 at 5:56 AM
