1998 Dodge Caravan Oil in radiator
20,000 MILES • 6 CYL • FWD • AUTOMATIC
RICKY GARCIA
Oil in radiator
I've got oil in my radiator.
I've never run across this type of thing before could I have a bad freeze plug? It poured all the water out last nite after driving 200 mile . I replaced the thermostat and the bypass hose.
Sep 29, 2008 at 9:52 AM
  • 75,988 POSTS
You sure its not transmission fluid? if it is engine oil-could mean a blown headgasket/cracked head or block-Get it pressure tested to find out where its leaking.
Sep 29, 2008 at 9:58 AM
