1998 Dodge Caravan not startin
MATT0007
1998 Dodge Caravan 6 cyl Front Wheel Drive 150000 miles
i got in the van and it started and died out. i repeated this three times and then its not doing anything. the tachs stopped workin but everything else electrical works just find. i just replced the battery and it has plenty of juice. what could be the problem?
May 2, 2010 at 6:47 AM
  • 75,988 POSTS
Do below to determine if its a fuel or spark issue and get back with some testing results we start here.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 2, 2010 at 8:21 AM
