1998 Dodge Caravan No windshield washer in front window
HOCKEY
1998 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I get windshield washer in the back rear window but not the front window of the van. Any thoughts and if it is the pump can u tell me how to fix it and test to ensure that it is the pump and not a clogged hose. thx for teh reply. How diffficult is the fix on a scale of 1 to ten
Nov 2, 2008 at 1:23 AM
  • 110,251 POSTS
Hi:
When you push the button for the front washer fluid, do you hear the pump run? If not, get a test light and a helper. On the washer bottle bottom, you will find the pump. Check. Remove the electrical plug, and with the test light, check for power when your helper pushes the button. If you have power, the pump needs replaced.
On a scale of 1 to 10, I give it a 3.
Let me know if you have any other questions.
Nov 7, 2008 at 4:10 AM
