1998 Dodge Caravan Washer Pumps Circuit
156,000 MILES • 6 CYL • FWD • AUTOMATIC
XDGT03
Both my front and rear washer pumps stopped working. Both motors work and the lines are not clogged. But when I push either the end of the multi-function stalk or the rear washer button on the dash neither pump will work. I checked all the fuses under the dash and under the hood. There is nothing labeled indicating the pumps. All the fuses are good.
Is there a fuse or relay somewhere else?
What could be the problem?
Thanks, Scott
Dec 22, 2009 at 1:45 AM
CARADIODOC
  • 34,397 POSTS
If "both motors work", how are you making them work? Do you hear the pump motors run? Do the wiper motors make three swipes when you press the washer buttons?
caradiodoc
Dec 25, 2009 at 1:14 PM
XDGT03
Both pumps were put to a separate power supply and both pumped. I new pump was connected to the wiring harnesses and did not work.
Yes, the wipers make the 3 swipes when the pump switches are pressed.
Dec 26, 2009 at 1:50 AM
CARADIODOC
  • 34,397 POSTS
Thanks for the dandy information. I would have done the same test, but most people don't have the knowledge to use a separate power supply so I couldn't assume anything.
Both washer motors receive 12 volts from PTC7. That's a 6 amp positive temperature coefficient current limiter. A PTC is a very low resistance semiconductor material up to its current rating. Above that rating, it goes to a near open circuit. When the overload is removed, the resistance goes back down to near 0 ohms. The change occurs almost instantly.
The first step is to check for 12 volts at either motor, dark blue wire, when the ignition switch is turned on. If it's missing, unplug both motors, turn the ignition switch off, and measure the resistance on that circuit to ground. If you find near 0 ohms, one of the wires is grounded. If there's high resistance, suspect a corroded connector pin # 9 at the junction block / body computer. I suppose the PTC could be open too, but I've never heard of one failing. A problem in this circuit would cause both washers to stop working at the same time.
If you do have 12 volts on the dark blue wires, things get pretty straight forward for the front washer. To turn the motor on, the second wire, brown, is grounded by the switch, but the wire goes through the junction block first. This is where the body computer senses the request for the washer and activates the wiper for three swipes. The fact that your wiper runs when pressing the washer button proves the switch is ok.
The rear washer is controlled by the body computer when it gets a signal from the heater / ac controller. All information is sent between the two computers on a single wire. Both of these computers have had an extremely high failure rate. I'm afraid I don't know of any way to diagnose the problem other than just trying new computers. The body computer is very difficult to replace. It is hidden against the firewall in front of the brake pedal. The HVAC controller is real easy to replace, (it is built into the bezel around the radio), but there may be another problem. The unit might have to be calibrated so it knows the position of every vent and temperature door and the characteristics of the AC evaporator temperature sensor. I don't know about '98 models, but for '97, it was extremely frustrating trying to get the "cool down" test to pass, and it won't work if the AC system isn't working properly. When it doesn't pass, the six yellow leds in the switches will flash. That is very annoying. The same recalibrations must be done when the battery is disconnected or run dead.
I think I would worry about the front washer first since it should run without any involvement with computers. Hopefully the problem will also be the cause of the dead rear washer.
caradiodoc
Dec 26, 2009 at 3:16 PM
XDGT03
Thanks for the info. It seems strange that a 6 amp draw would not be fused but controlled through the bcm. Nonetheless, after some searching I found that you can "reset" the bcm by pulling the 10 amp IOD fuse from the power distribution center under the hood. You pull it for about 2 minutes and replace. After this I started the van and both pumps worked.
Thanks for all the info and timely responses.
Dec 27, 2009 at 12:14 AM
CARADIODOC
  • 34,397 POSTS
Wonderful news.
I can't explain the front washer except that I only have a '97 service manual. I know that in '97, disconnecting the battery would result in flashing leds in the buttons, and you would have to do the recalibration procedures. If you didn't have to do that, there are obviously differences between the years. In my book, the front washer gets 12 volts directly from the ignition switch and is grounded directly by the washer switch. I don't see anything to reset by disconnecting the battery. The rear washer is a different story. There are two computers involved in the ground circuit.
The PTC takes the place of a fuse. It is a two-terminal semiconductor that instantly goes to an open circuit when overloaded and instantly goes to 0 ohms when the short is gone. If you solder one in the middle of a test lead, the lead will act just like a wire, but if you connect it right across the battery terminals, nothing happens.
caradiodoc
Dec 27, 2009 at 9:06 AM
