Engine Performance problem
1998 Dodge Caravan 4 cyl Front Wheel Drive 113000 miles
2.4L engine ran but had a rod knock. Replaced with a running engine from a 98 Cirrus. Engine started immediately after replacement, warmed up, checked fluid levels, etc. Let it set overnight, started up for a test drive, drove 2 miles, let set for 10 minutes, drove 2 more miles, let set for 5 minutes, drove 150 yards, engine stalled and would not restart. Scanned for codes, none present. Checked for spark, good on all 4 plug wires; mechanical timing checks good; cam and crank sensors check ok and sync per scanner; fuel pressure and volume check ok; injectors pulse per noid light; all injectors trigger with scanner; TPS voltage within range; unplugged MAP sensor doesn't allow to start; compression is 100 across all cylinders. What did I miss?
Apr 27, 2008 at 11:35 AM
