map sensor
200,000 MILES • 6 CYL • FWD • AUTOMATIC
CLOUDFALL
where is the map sensor?
Jun 11, 2008 at 5:32 AM
OBXAUTOMEDIC
  • 3,711 POSTS
It is located on the Plenum it has a single vacuum line going to it and and electrical connection.
See the diagram below for location. My manual has the same diagram for all 3 engines.
Jun 13, 2008 at 1:40 AM
MANOK
  • 8 POSTS
hi bob and ken,
i just want to ask where the MAP sensor is located on my vehicle. thanks..
Jan 27, 2019 at 12:10 AM (Merged)
  • 110,245 POSTS
I believe it mounted on the throttle body. If not, let me know and I'll do more checking for you.
OCASIO123
can you tell me where thw map sensor is located? and how to replace it?
BMRFIXIT
  • 19,053 POSTS
what do you have for engine size
right or left side of the intake manifold
SOLARBLU
Electrical problem
1991 Dodge Caravan 4 cyl Front Wheel Drive Automatic
can you tell me where the map sensor and the fuel position sensor is located on a 1991 dodge caravan 2.4L. If possible please send pic or diagram. Thanks.
Jan 27, 2019 at 12:11 AM (Merged)
  • 110,245 POSTS
The map sensor is on the right side of the firewall and I think you mean throttle position sensor. It is on the throttle body.
https://images.2carpros.com/forum/automotive_pictures/249084_5_34.jpg
