1998 Dodge Caravan Is a rebuilt transmission needed
121,000 MILES • 6 CYL • 2WD • AUTOMATIC
PMENUEZ
I think my transmission is dead but hoping that it's something else. Before the failure when I accelarated from a stop the transmission would clunk - like something was loose. Clunk every couple seconds until I slow down the accelaration. If fact I could force it to do the clunk or not by accelarating slow or fast.
The failure happen on a clunk - no forward gears work but reverse works fine. When I put it in first gear it sounds and feels like it's going to start but is is just slipping.
Any hope that it is something other than the tranny ?
Oct 31, 2008 at 10:05 AM
  • 110,246 POSTS
Hi:
When you put the car in drive, give it some gas and tell me if the speedometer registers.
Nov 7, 2008 at 5:34 AM
PMENUEZ
No. Nothing registers on the speedometor when I put it in gear, 1st, 2nd and drive. Reverse still works.
Nov 7, 2008 at 2:06 PM
  • 110,246 POSTS
It sounds to me like there is an internal transmission problem. Based on our conversation, you will most likely need to see a mechanic.
If you have any other questions, let me know.
Nov 10, 2008 at 6:07 AM
