1998 Dodge Caravan intermittent starting
L RANDALL
1998 Dodge Caravan 131,00 miles
Car towed 4x in 6 mo. Ea time it starts to crank, then dies, depress accelerator, does not help. Dashboard lights all on. If try 2-3x in a row, won't even crank. If wait 1/2 hour - 1 day it will start. Problem always gone by the time mechanic gets car. 1 dealer + 2 repair shops have not found prob. Ignition switch, starter, cam sensor,crank shaft sensor replaced. Body control module checked-ok. Another problem, smell gas after each episode. Also, when key unlocks passenger door, driver door locks. Thought this was screwed up security system-tried not locking doors-still had starting problem. Dealership says no anti-theif. Please help! Running out of friends' cars to borrow.
Jan 18, 2009 at 4:08 PM
SERVICE WRITER
  • 9,123 POSTS
This is what I want you to try. The next time you have a no start. Unplug the instrument cluster. and see if it starts.
These have had solder problems and can cause this.
If this works, you can resolder the circuit board or replace the cluster.
Jan 19, 2009 at 8:28 PM
L RANDALL
You suggested unplugging the instrument cluster the next time I have this problem. I've looked through my manual--it tells me what the instrument cluster is, but not how to unplug it. Suggestions?
Jan 20, 2009 at 10:56 PM
SERVICE WRITER
  • 9,123 POSTS
Removal
Remove instrument cluster bezel.
Remove screws holding instrument cluster to instrument panel.
Rotate top of cluster outward.
Remove instrument cluster from instrument panel.
Disconnect wire connector from back of instrument cluster.
Remove instrument cluster.
INSTALLATION
Place instrument cluster in instrument panel, bottom first.
Connect wire connector into back of instrument cluster.
Position instrument cluster in instrument panel.
Install instrument cluster mounting screws to instrument panel.
Install instrument cluster bezel.
I don't have a picture, but this should explain it.
Jan 21, 2009 at 12:24 AM
L RANDALL
Thank you, I've had the intrument cluster repaired--many loose connections. I heard that the Chrysler products frequently have this problem. So far I've not had a starting problem. Thank you again.
Feb 1, 2009 at 10:38 AM
SERVICE WRITER
  • 9,123 POSTS
Excellent!!!
Thanks for updating!
Feb 3, 2009 at 11:16 AM
