When it doesn't not start, nothing happens when turning the ignition key?
163,000 MILES • 6 CYL • FWD • AUTOMATIC
MSOWKA
My Grand Caravan has seemingly random intermittent starting problems. Sometimes it starts, and sometimes it doesn't . When it doesn't not start, nothing happens when turning the ignition key, not starter, not engine turnover - nothing. The next day, it may well start fine.
The van also has had several episodes where the instrument cluster completely goes out - all gauges - during driving. The van continues to operate during the instrument cluster failure, and eventually, they come back on.
I have had the ignition switch replaced 3 times, and also the controller, but the van still has the same issues.
Sep 18, 2009 at 3:53 AM
SQM
  • 6,383 POSTS
This issue you are motioning sounds like faulty ignition switch. However since you have already have that replaced, it could a issue with the wiring for the ignition switch.
As you also experience the dash gauge outage it points to a wiring issue.
You will have to trace the wires to find the issue. It could be weak ground or a wire that could be corroded.
Here is a helpful article on how to check wiring:
I have included the wiring schematics for your reference.
Sep 21, 2021 at 3:22 PM
