Dear Jerry32:
Thanks for your reply. I found my Haynes manual and it told me what to do. It states that you have to put your key in and turn it to the run position and use a screw driver to push in on the lip and the cylinder will come out. My problem was that the key would not turn, so I took a plier and screw driver and hit the lip and then the key turned and then the cylinder came out. I hear you on the FUNDS ISSUE. I'm an electrician, business is dead. Autozone has it listed for $14.99. I will check it out tomorrow. In the mean time I did what you said about the graphite, and it's working.
Thanks for your quick reply and good luck to you on the funds issue.
Gg1328
Wednesday, December 17th, 2008 AT 4:56 PM
