1998 Dodge Caravan Horn Not Working
120,000 MILES • 6 CYL • FWD • AUTOMATIC
NCGENT2004
The horn doesn't work on my Dodge Caravan.
I've troubleshot the problem, checked the fuse and relay, shorted the relay and the horn sounds so I know it's not a problem at that end.
I believe the problem's at the horn switch in the steering wheel. I took off the center of the steering wheel to get access to the horn switch and see I'm going to have to remove the air bag assembly. I've not done any repairs involving removing an air bag so I want to make sure I'm following correct procedure before attempting to remove the air bag in order to get access to the horn switch (behind the air bag). What are the instructions to remove the air bag in order to get access to the horn switch? Thanks.
Feb 16, 2009 at 2:04 AM
BMRFIXIT
  • 19,053 POSTS
Have your VIN # ready on hand and call your local dealer as they did have a recall on the spring switch
witch what you need
very common
good luck
Feb 16, 2009 at 10:43 AM
