1998 Dodge Caravan Heating problem
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
RODENBAUGH
When I turn on the heat in the van is only gets a little warm. I believe it may be a clogged line in the heating coil. The temp guage says the engine is warm. Will flushing the radiator and engine of anti-freeze solve my problem?
Jan 29, 2008 at 12:29 AM
MIKE H R
  • 3,094 POSTS
if you are going to flush the system, back flush the whole system basically, they have kits that can be put inline, once installed you can flush the system with a garden hose. After flushing the system as always i would suggest changing the thermastat.
Jan 29, 2008 at 12:52 AM
