1998 Dodge Caravan Heating problem
RODENBAUGH
  • 1998 DODGE CARAVAN
  • 6 CYL
  • 200,000 MILES
When I turn on the heat in the van is only gets a little warm. I believe it may be a clogged line in the heating coil. The temp guage says the engine is warm. Will flushing the radiator and engine of anti-freeze solve my problem?
Tuesday, January 29th, 2008 AT 8:29 AM
MIKE H R
  • 3,094 POSTS
If you are going to flush the system, back flush the whole system basically, they have kits that can be put inline, once installed you can flush the system with a garden hose. After flushing the system as always I would suggest changing the thermastat.
Tuesday, January 29th, 2008 AT 8:52 AM
