1998 Dodge Caravan heater control
TOM KARELS
Electrical problem
1998 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Where is the mode door acturator and how do I replace it.
Dec 12, 2008 at 11:15 AM
2CARPRO JACK
  • 11,533 POSTS
For the auxilary unit, you need to remove the right rear panel to gain access to the HVAC assembly.You will need the proper equipment to evacuate the a/c system to get the floor flange apart to remove the rear unit.then remove heater hoses adn mounting bolts holding unit to body and remove the entire unit. Remove the 3 screws holding actuator to the unit and replace it, reverse for reassembly
Dec 16, 2008 at 2:05 AM
