1998 Dodge Caravan head gasket
CHRISMORN
Engine problem
1998 Dodge Caravan 6 cyl Wheel Drive Type unknown Automatic 117. miles
do you know how much it would be to get the head gaskets replaced? i think that is what the problem is,not alot of white smoke comes out the tail pipe, it does not overheat never did, and not picking up speed like it did? really don't know what it is, need help thanks
Dec 28, 2007 at 4:53 AM
RISLEYSROOST
Blue Smoke = Oil
Black Smoke = Fuel
White Smoke = Water
However, When you first start your car, if you have a lot of water in your muffler, it will condensate or blow white smoke but will stop if it's not the head gasket.
To check if the problem is the head gasket, after running the car for at least 1/2 an hour, shut it off and wait 5 minutes. Start it up again and watch for white smoke. You can also look at the oil fill cap and see if there's a thick white oily film on it.
Cost to replace it will depend on who you take it to and whether there are other complications along with the initial blown gasket -- could be as little as $800 or as high as $2000
Good luck!!!
Jan 2, 2008 at 7:29 AM
