1998 Dodge Caravan fuel hose?
146,000 MILES • 6 CYL • FWD • AUTOMATIC
LEIAODEN
I have a 1998 Dodge Caravan. I am not sure what the part is called that I'm looking for, but the rubber hose that goes from behind the fuel door where you pump gas into that leads into the gas tank itself has a hole in it, and I am unable to put any fuel into my van as it leaks onto the ground instead of into the tank. I have removed the hose and have been unsuccessful on finding another one. Any suggestions on where I might call, or even what the exact name of the hose is so that I may get my van back on the road again? Thank you very much.
Apr 8, 2008 at 1:54 PM
BMRFIXIT
  • 19,053 POSTS
check with your local dodge dealer
I think you are looking for a filler neck
Apr 8, 2008 at 2:20 PM
