1998 Dodge Caravan filter change
185,000 MILES • 6 CYL • FWD • AUTOMATIC
NODALDRICH
I changed my filter and about 6 qts of oil in my transmission on my 98 dodge caravan, BUT in the bottom of the pan was some shavings and a bunch of little needle rollers, the transmission works fine, i can expect future problems, where are the rollers from??
any easy fix before total rebuild??
I changed the oil because the oil change people said i needed it flushed and recommendations were not to flush it on a high mileage vehicle.
thanks Don
Aug 16, 2010 at 1:20 AM
  • 110,248 POSTS
The must be from one of the bearings. If the trans is still shifting and working good and not making any noise, I would drive it.
Are you sure they are roller bearings? Were they attached to the magnet in the pan?
Aug 16, 2010 at 3:56 PM
NODALDRICH
they were attached to the magnet, they were about 1/4 inch long i/8 dia. 6-8 pieces
it drives fine just makes me nervous seeing the stuff in the pan
thanks Don
Aug 17, 2010 at 5:20 AM
  • 110,248 POSTS
The must be from a roller bearing, but it would be making noise if there was a bad one.
Aug 17, 2010 at 6:25 PM
NODALDRICH
any idea what in the transmission would use a bearing that small
Aug 18, 2010 at 2:03 AM
  • 110,248 POSTS
There are roller bearing in the planetary gears.
Aug 18, 2010 at 3:18 PM
