1998 Dodge Caravan ERG valve & Fuel filter
THEPAINTER
Engine Performance problem
1998 Dodge Caravan 6 cyl Automatic 150000 miles
what is the normal length of time needed to replace the ERG valve and Fuel Filter?
Sep 23, 2009 at 7:05 AM
BMRFIXIT
  • 19,053 POSTS
No need to replace EGR valve as long as its working and doing its job and no check engine light on for it should be fine
as for the fuel filter some you replace only with the fuel pump and when pump fail you drop the tank and replace
and other on the out side
recommend replacement with a full tune up and or if you have trouble
Sep 27, 2009 at 12:01 AM
