1998 Dodge Caravan Electric windows
TPBOWL
Electrical problem
1998 Dodge Caravan 6 cyl Front Wheel Drive Automatic 150K miles
The electric windows are failing. These events occurred over an extended period of time, happening one at a time:
- the left rear window stopped working
- then the right rear window stopped working
- then the passenger front window began to respond intermittently to the passenger door button, but worked fine with the drivers-side button, then the window stopped working altogether, though you can hear the motor when using the driver-side button
In addition, the lights blink on two rear wiper buttons as well as the recirculating air and AC buttons; all buttons and equipment work
Possible BCM problem?
Thanks
Mar 27, 2008 at 1:09 PM
BMRFIXIT
  • 19,053 POSTS
it will be a plus if you scan the BCM and read its data
do a function test
Mar 27, 2008 at 2:05 PM
