Engine Cooling problem
1998 Dodge Caravan 6 cyl Front Wheel Drive Automatic
i need to change the lower radiator hose. where is the drain plug for the radiator located and can it be remove/opened without special tools. i need to raise the front to get clearance. where should I put the jack stands?
Feb 27, 2009 at 11:08 AM
