The instrumentation gauges are contained in a subdial assembly called the instrument cluster
to remove
Disconnect and isolate the battery negative cable.
Remove Over Steering Column Bezel by lifting it straight up with a firm pull.
Remove the four cluster bezel attaching screws.
Tilt the steering column in the full down position.
Pull rearward on the cluster bezel and remove.
Remove the four screws holding instrument cluster to instrument panel.
Rotate top of cluster outward.
Disconnect the cluster harness connector.
Remove instrument cluster from instrument panel
Tuesday, January 26th, 2010 AT 9:55 PM
